TransactionMode Property
The TransactionMode property specifies whether a manual, magnetic or EMV transaction is used.
[int=] SiteKiosk.Plugins("SiteCash").Devices("CreditCard").
CreateCardInfo().TransactionMode
Integer that specifies or retrieves the transaction mode.
Manual = 0
Magnetic = 1
EMV = 2
The following example shows the transaction mode in an alert window.
creditcard = SiteKiosk.Plugins("SiteCash").Devices("CreditCard");
ccardinfo = creditcard.CreateCardInfo();
alert(ccardinfo.TransactionMode);
