Open Method
The Open method opens a query that returns a result.
    DatabaseQuery.Open(query)
    query String that specifies the query.
    Use the other methods of this object to access the result.
    The following example opens a database query and displays the last returned row.
    dbquery = SiteCafe.Server.CreateDatabaseQuery();
    dbquery.Open("SELECT * FROM users");
    dbquery.MoveLast();
    alert(dbquery.GetRowData());
