Force24Hour Property
The Force24Hour property indicates whether to use 24 hour mode.
DateTimeFormatter.Force24Hour [=bool]
Boolean value that specifies or retrieves the 24hour status.
The following example shows the hour and minute of the last logfile message.
last = SiteKiosk.Logfile.LastMessages.Count;
myDate = SiteKiosk.Logfile.LastMessages.Item(last).LocalTime;
myDTF = SiteKiosk.SiteKioskUI.CreateDateTimeFormatter();
myDTF.Force24Hour = true;
myDTF.TimeFormatString = "hh:mm:ss";
alert(myDTF.FormatTime(myDate));
