TimeFormatString Property
The TimeFormatString property contains a string that specifies the time format.
DateTimeFormatter.TimeFormatString [=str]
String that specifies or retrieves the format.
The following example shows the hour and minute of the last logfile message.
last = SiteKiosk.Logfile.LastMessages.Count;
myDate = SiteKiosk.Logfile.LastMessages.Item(last).LocalTime;
myDTF = SiteKiosk.SiteKioskUI.CreateDateTimeFormatter();
myDTF.TimeFormatString = "hh:mm";
alert(myDTF.FormatTime(myDate));
