AccessDevice Property
The AccessDevice property indicates whether the device is an access device.
[bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).AccessDevice
Boolean value that retrieves the access device status.
For example, the time limiter or SiteCafe in time mode is an access control device.
A payment device like a coin validator is not an access device.
The following example determines whether the first existing device is an access device and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).AccessDevice);
