Active Property
The Active property indicates whether the device is active.
[bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).Active
Boolean value that retrieves the activity status.
The following example determines whether the first existing device is active and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).Active);
