EnableDevice Method
The EnableDevice method enables or disables the device.
SiteKiosk.Plugins("SiteCash").Devices2.Item(index).EnableDevice(enable)
enable |
Boolean value that specifies whether to enable the device. |
The following example disables the first existing device.
SiteKiosk.Plugins("SiteCash").Devices2.Item(1).EnableDevice(false);
