EscrowDevice Property
The EscrowDevice property indicates whether the device is an escrow device.
    [bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).EscrowDevice
    Boolean value that retrieves the escrow status.
    The following example determines whether the first existing device is an escrow device and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).EscrowDevice);
