EscrowEnabled Property
The EscrowEnabled property indicates whether escrow functionality is enabled.
[bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).EscrowEnabled
The following example determines whether escrow functionality is enabled for the first existing device and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).EscrowEnabled);
