HtmlDialogSnippet Property
The HtmlDialogSnippet property contains a HTML snippet to display in a HTML Dialog.
[str=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).
HtmlDialogSnippet
String that retrieves the HTML snippet.
The following example shows the HTML snippet of the first existing device in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).HtmlDialogSnippet);
