Name Property
The Name property contains a long device description.
    [str=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).Name
    String that retrieves the long description.
    The following example shows the long description of the first existing device in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).Name);
