SequentialReturn Property
The SequentialReturn property indicates whether coins can only be returned in the same order as inserted.
[bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).
SequentialReturn
Boolean value that retrieves the sequential return status.
The following example determines whether the first existing device can return coins only in the same order as inserted.
alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).SequentialReturn);
