SingleReturn Property
The SingleReturn property indicates whether the device allows returning single coins/notes.
    [bool=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).SingleReturn
    Boolean value that retrieves the single return status.
    The following example determines whether the device allows returning single coins/notes and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).SingleReturn);
