BytesDownloaded Property
The BytesDownloaded property contains the number of bytes currently downloaded.
    [long=] SiteKiosk.Network.Downloads.Item(index).BytesDownloaded
    Long value that retrieves the number of bytes.
    The following example shows the progress of a download.
    <div id="id_progr">0 bytes</div>
    SiteKiosk.Network.Downloads.OnNewDownload = OnNewDownload;
    function OnNewDownload(newdownload)
       mydownload = newdownload;
       mydownload.OnProgress = OnProgress;
    function OnProgress()
       id_progr.innerHTML = mydownload.BytesDownloaded + ' bytes';
