FileName Property
The FileName property contains the filename.
    [str=] SiteKiosk.Network.Downloads.Item(index).FileName
    String that retrieves the name of the file.
    The following example shows the filename of the first download.
    alert(SiteKiosk.Network.Downloads.Item(1).FileName);
