Flags Property
The Flags property contains the flags of the download.
    SiteKiosk.Network.Downloads.Item(index).Flags [=long]
    Long value that specifies or retrieves the flags.
    Possible values are:
    0 : (default), file will be opened directly after the download
    1 : (internal), file will be downloaded to the temporary files folder and will not be opened
    2 : (internal), file will not ne opened after download but copied into the configured folder
    3 : (internal), file will be downloaded into the cache and not be started
    The following example shows the flags of the first download in an alert window.
    alert(SiteKiosk.Network.Downloads.Item(1).Flags);
