ClearDownloadDirectories Method
The ClearDownloadDirectories method deletes the files in all download directories.
SiteKiosk.Network.Downloads.ClearDownloadDirectories()
Depending on the settings of the SiteKiosk configuration, this method deletes all files or only old files.
The following example deletes the files in all download directories.
SiteKiosk.Network.Downloads.ClearDownloadDirectories();
