DownloadLimit Property
The DownloadLimit property contains the maximum size of downloads in bytes.
[long=] SiteKiosk.Network.Downloads.DownloadLimit
Long value that retrieves the maximum number of bytes.
The maximum download size can be defined in the SiteKiosk configuration.
The following example shows the maximum download size in an alert window.
alert(SiteKiosk.Network.Downloads.DownloadLimit);
