OnNewDownload Event
Fires when a new download has been started.
SiteKiosk.Network.Downloads.OnNewDownload = handler
The following example removes every download directly when it has been started.
SiteKiosk.Network.Downloads.OnNewDownload = OnNewDownload;
function OnNewDownload(newdownload)
SiteKiosk.Network.Downloads.Remove(newdownload);
