OnProgressChange Event
Fires when the sending progress changed.
    EmailJob.OnProgressChange = handler
    current Long value that contains the current progress.
    max Long value that contains the maximum progress.
    Fires after each percent of progress until 100 percent are reached.
    The following example sends an email and shows the current progress.
    <div id="id_progress"></div>
    function OnProgressChange(cur, max)
       id_progress.innerHTML = "Progress: " + cur + " of " + max;
    mymail = SiteKiosk.Email.CreateJob(false);
    mymail.OnProgressChange = OnProgressChange;
    mymail.POPServer = "mypopserver.com";
    mymail.POPPort = 110;
    mymail.Username = "myusername";
    mymail.Password = "mypassword";
    mymail.SMTPServer = "mysmtpserver.com";
    mymail.SMTPPort = 25;
    mymail.Authentication = 2;
    mymail.SetSender("me@myserver.com", "My name");
    mymail.AddRecipient("recipient@server.com");
    mymail.Subject = "This is the subject.";
    mymail.PlainBody = "This is the content.";
    mymail.Send(0, false, true);
