OnStatusTextChange Event
Fires when the sending status text changes.
    EmailJob.OnStatusTextChange = handler
    status String that contains the current status text.
    The following example shows the current status text when it has been changed.
    <div id="id_status"></div>
    function OnStatusTextChange(status)
       id_status.innerHTML = "Status: " + status;
    mymail = SiteKiosk.Email.CreateJob(false);
    mymail.OnStatusTextChange = OnStatusTextChange;
    mymail.POPServer = "mypopserver.com";
    mymail.POPPort = 110;
    mymail.Username = "myusername";
    mymail.Password = "mypassword";
    mymail.SMTPServer = "mysmtpserver.com";
    mymail.SMTPPort = 25;
    mymail.Authentication = 2;
    mymail.SetSender("me@myserver.com", "My name");
    mymail.AddRecipient("recipient@server.com");
    mymail.Subject = "This is the subject.";
    mymail.PlainBody = "This is the content.";
    mymail.Send(0, false, true);
