Send Method
The Send method sends the email.
    EmailJob.Send(timeout, sync, requestconnection)
    timeout Long value that specifies the timeout period.
    sync Boolean value that specifies if the method should run synchronously or not.
    requestconnection Boolean value that specifies if a connection should be established if offline.
    The following example sends an email.
    mymail = SiteKiosk.Email.CreateJob(false);
    mymail.POPServer = "mypopserver.com";
    mymail.POPPort = 110;
    mymail.Username = "myusername";
    mymail.Password = "mypassword";
    mymail.SMTPServer = "mysmtpserver.com";
    mymail.SMTPPort = 25;
    mymail.Authentication = 2;
    mymail.SetSender("me@myserver.com", "My name");
    mymail.AddRecipient("recipient@server.com");
    mymail.Subject = "This is the subject.";
    mymail.PlainBody = "This is the content.";
    mymail.Send(0, false, true);
