IsProcessRunning Method
The IsProcessRunning method determines if a specified process is running.
[bool=] SiteKiosk.ExternalApps.IsProcessRunning(path)
path |
String that specifies the path to the application. |
Returns a Boolean value that contains the running status.
The following example determines if the first configured external application is
currently running using the path of this application.
path = SiteKiosk.ExternalApps.Item(1).Path;
alert(SiteKiosk.ExternalApps.IsProcessRunning(path));
