RunElevated Method
The RunElevated method runs a configured external application as administrator.
    SiteKiosk.ExternalApps.RunElevated(path)
    path String that specifies the path to the application.
    Note that in order for SiteKiosk to be able to automatically close applications started through the SiteKiosk Object Model, they need to be in the list of external applications. External applications can be configured in the SiteKiosk configuration.
    Use slash instead of backslash in the path string.
    The following example runs an external application as administrator.
    SiteKiosk.ExternalApps.RunElevated("c:/windows/notepad.exe");
