RunSync Method
 The RunSync method runs a configured external application and returns the exit code when it has been closed.
    [long] = SiteKiosk.ExternalApps.RunSync(path, timeout)
    path String that specifies the path to the application.
    timeout Long value that specifies the timeout period.
    Returns a Long value containing the exit code.
    Setting the timeout parameter to -1 means that there is an infinite period of time.
    If a time out occurres an exception will be thrown.
    External applications can be configured in the SiteKiosk configuration. Use slash instead of backslash in the path string.
    The following example runs an external application and shows an alert window if a time out occurres.
    try
       myexitcode = SiteKiosk.ExternalApps.RunSync("c:/myapp.exe", 20);
    catch(e)
       alert("Time out");
