AddParameter Method
The AddParameter method adds a parameter to the request.
HTTPPost.AddParameter(name, value)
name |
String that specifies the name of the parameter. |
value |
String that specifies the value of the parameter. |
The parameter and its value will be added to the request body: 'name=value'.
The following example sends a HTTP request to Yahoo and displays the response.
mypost = SiteKiosk.Network.CreateHTTPPost();
mypost.OnPostComplete = OnPostComplete;
function OnPostComplete(success, response)
if (success<0) {alert("Error");} else document.write(response);
mypost.AddParameter("p", "sitekiosk");
mypost.Submit("http://us.yhs4.search.yahoo.com/");
