AddParameterNoValue Method
The AddParameterNoValue method adds a string to the request body.
HTTPPost.AddParameterNoValue(str)
str |
String that specifies the string to add to the request body. |
The following example sends a HTTP request with a specified request body.
mypost = SiteKiosk.Network.CreateHTTPPost();
mypost.OnPostComplete = OnPostComplete;
function OnPostComplete(success, response)
if (success<0) {alert("Error");} else document.write(response);
mypost.AddParameterNoValue("Request body");
mypost.Submit("http://www.anyaddress.com/");
