OnPostComplete Event
Fires when a request has been completed.
HTTPPost.OnPostComplete = handler
success |
HRESULT value that indicates if the request was successfull. |
response |
String that contains the response. |
A negative HRESULT value means failure, all other values mean success.
The following example sends a HTTP request to Yahoo and displays the response.
<div id="id_plugin">Add a plugin</div>
mypost = SiteKiosk.Network.CreateHTTPPost();
mypost.OnPostComplete = OnPostComplete;
function OnPostComplete(success, response)
if (success<0) {alert("Error");} else document.write(response);
mypost.AddParameter("p", "sitekiosk");
mypost.Submit("http://us.yhs4.search.yahoo.com/");
