Referer Property
The Referer property contains the referer of the request which will be transmitted as a part of the HTTP request header.
String that specifies or retrieves the referer.
The following example sends a HTTP request containing the referer.
mypost = SiteKiosk.Network.CreateHTTPPost();
mypost.OnPostComplete = OnPostComplete;
function OnPostComplete(success, response)
if (success<0) {alert("Error");} else document.write(response);
mypost.AddParameter("q", "sitekiosk");
mypost.Referer = "Terminal3";
mypost.Submit("http://us.altavista.com/web/results");
