SetAuthInfo Method
The SetAuthInfo method sets username and password which will be used if the specified URL requires an authentication.
HTTPPost.SetAuthInfo(username, password)
username |
String that specifies the username. |
password |
String that specifies the password. |
The following example sends a HTTP request to Yahoo and displays the response. Although it is not required, username and password are specified.
mypost = SiteKiosk.Network.CreateHTTPPost();
mypost.OnPostComplete = OnPostComplete;
function OnPostComplete(success, response)
if (success<0) {alert("Error");} else document.write(response);
mypost.AddParameter("p", "sitekiosk");
mypost.SetAuthInfo("myusername", "mypassword");
mypost.Submit("http://us.yhs4.search.yahoo.com/");
