Datatype Property
The Datatype property contains the name of the data type used to record the print job.
Datatype
The following example displays the name of the data type of the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Datatype);
