Document Property
The Document property contains the name of the print job document.
           Document
    String that retrieves the document name.
    For example, a document name could be "MS-WORD: Review.doc".
    See JOB_INFO_2 (MSDN) for further information.
    The following example displays the document name of the first available print job of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Document);
