DriverName Property
The DriverName property contains the name of the printer driver that should be used to process the print job.
           DriverName
    String that retrieves the driver name.
Remarks Examples
    The following example displays the printer driver name of the first available print job of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).DriverName);
