Info Property
The Info property contains an information string with some values of this object.
           Info
    String that retrieves the information.
    The following example displays the information string of the first available print job of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Info);
