IsWaiting Property
The IsWaiting property indicates whether the job waits for a command.
[bool=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
IsWaiting
The following example determines whether the first available print job of the first available printer waits for a command.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).IsWaiting);
