MachineName Property
The MachineName property contains the name of the machine that created the print job.
           MachineName
    String that retrieves the machine name.
Remarks Examples
    The following example displays the machine name of the first available print job of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).MachineName);
