Parameters Property
The Parameters property contains the print-processor parameters.
String that retrieves the parameters.
The following example displays the print-processor parameters of the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Parameters);
