Position Property
The Position property contains the job's position in the print queue.
[long=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
Position
Long value that retrieves the position.
The following example displays the position in the print queue of the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Position);
