PrinterName Property
The PrinterName property contains the name of the printer for which the job is spooled.
PrinterName
The following example displays the name of the printer for which the first available print job of the first available printer is spooled.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).PrinterName);
