PrintProcessor Property
The PrintProcessor property contains the name of the print processor that should be used to print the job.
PrintProcessor
The following example displays the name of the print processor that should be used to print the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).PrintProcessor);
