Priority Property
The Priority property contains the job priority.
[long=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
Priority
Long value that retrieves the priority.
Possible priorities are:
MAX_PRIORITY = 99
MIN_PRIORITY = 1
DEF_PRIORITY = 1
See JOB_INFO_2 (MSDN) for further information.
The following example displays the priority of the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Priority);
