Size Property
The Size property contains the size, in bytes, of the job.
[long=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
Size
Long value that retrieves the size.
The following example displays the size of the first available print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).Size);
