StartTime Property
The StartTime property contains the earliest time at which the job can be printed.
    [long=] SiteKiosk.Printer.Printers.Item(index1).Jobs.Item(index2).
            StartTime
    Long value that retrieves the time.
    This value is expressed as minutes elapsed since 12:00 AM GMT (Greenwich Mean Time).
    See JOB_INFO_2 (MSDN) for further information.
    The following example displays the earliest time at which the first available print job of the first available printer can be printed.
    alert(SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1).StartTime);
