Docked Property
The Docked property indicates whether the touch screen keyboard is docked or not.
    [bool=] SiteKiosk.Keyboard.Docked
    Boolean value that retrieves the docked status of
    the touch screen keyboard.
    In order to be able to use this property, you must have configured a touch screen keyboard.
    The following example reads the docked status and shows it in an alert window.
    alert(SiteKiosk.Keyboard.Docked);
