Floating Property
The Floating property indicates whether the touch screen keyboard is floating or not.
[bool=] SiteKiosk.Keyboard.Floating
Boolean value that retrieves the floating status of the touch screen keyboard.
In order to be able to use this property, you must have configured a touch screen keyboard.
The following example reads the floating status and shows it in an alert window.
alert(SiteKiosk.Keyboard.Floating);
