Initialized Property
The Initialized property indicates whether a touch screen keyboard is used or not.
    [bool=] SiteKiosk.Keyboard.Initialized
    Boolean value that retrieves the initialized
    status of the touch screen keyboard.
    The following example reads the initialized status and shows it in an alert window.
    alert(SiteKiosk.Keyboard.Initialized);
