Left Property
The Left Property specifies how far from the left of the SiteKiosk MainWindow the keyboard is.
[long=] SiteKiosk.Keyboard.Left
Long value that specifies specifies how far from the left of the SiteKiosk MainWindow the keyboard is.
In order to be able to use this property, you must have configured a touch screen keyboard.
The following example reads the Left offset and shows it in an alert window.
alert(SiteKiosk.Keyboard.Left);
