MoveTo Method
The MoveTo Method moves the onscreen keyboard to a specified position.
SiteKiosk.Keyboard.MoveTo(left, top)
left |
Long value that specifies specifies how far from the left of the SiteKiosk MainWindow the keyboard should be. |
top |
Long value that specifies specifies how far from the top of the SiteKiosk MainWindow the keyboard should be. |
The following example moves the keyboard to the bottom right corner of the screen.
var mainwindow = SiteKiosk.WindowList.MainWindow;
var left = mainwindow.Width - SiteKiosk.Keyboard.Width;
var top = mainwindow.Height - SiteKiosk.Keyboard.Height;
SiteKiosk.Keyboard.MoveTo(left, top);
