Small Property
The Small property indicates whether the touch screen keyboard is minimized or not.
SiteKiosk.Keyboard.Small [=bool]
Boolean value that specifies or retrieves the small status of the touch screen keyboard.
In order to be able to use this property, you must have configured a touch screen keyboard.
The following example reads the small status and shows it in an alert window.
alert(SiteKiosk.Keyboard.Small);
