Top Property
The Top Property specifies how far from the top of the SiteKiosk MainWindow the keyboard is.
    [long=] SiteKiosk.Keyboard.Top
    Long value that specifies specifies how far from the
    In order to be able to use this property, you must have configured a touch screen keyboard.
    The following example reads the Left offset and shows it in an alert window.
    alert(SiteKiosk.Keyboard.Top);
